I am considering it for my next oil change in a older Toyota. I am looking for a oil that is in the higher viscosity range of 30 grade oil when hot, but one that flows better at cold start. Mobil 10w30 HM is a higher viscosity oil, but it gave me some valve train noise at cold start and some consumption. The car did not like Mobil 1 10w-40 HM. Valve train tapping at cold start and enigine seemed a bit labored at idle...I dumped that oil in a week, so can't comment on consumption. Currently using Mobil 1 Extended Performance 10w30 + 1 10oz can of Lubro Moly MoS2 addit...my car likes it...no valve train tapping at cold start....after 500 miles, consumption seems nil. I like to experiment and next oil change I will try on of these oils listed below. My owners manual lists oils I can use as going from 5w30 all the way to 20w-50, depending on temp.
Amsoil 10w30 ACD
Redline 10w30
Lubro Moly 5w30 67 @ 40C, 12.0 @ 100C vis 178
Lubro Moly 5w-40
Mobil 1 ESP 5w30 72.8 @ 40c, 12.1 @ 100c vis 164
GC 0w-30
