Originally Posted By: clinebarger
A misfire is generally worse when the Converter Clutch locks-up, Lock-up happens at high speeds than when your symptoms are happening.
The 4L60E has 2 "Mechanical Diodes"/"One Way Clutches".
The Lo/Reverse Roller Clutch & the Input Sprag.
When taking off in 1st gear with the Shifter in D4, Your relying on BOTH too hold ALL the input torque.
The Input Sprag is MUCH weaker than the Lo/Reverse Roller Clutch.
The next time the symptoms come up, Pull into D2 (This allows the Overrun Clutches too come "On" & bypass the Input Sprag), If the symptoms go away AND it's repeatable.....D2=no shutter.....D4= shutter, The Input Sprag is about too FAIL!
If the symptoms persist, Pull in down into D1, This Bypasses BOTH L/R Roller Clutch & Input Sprag, If the symptom now disappear.....The Lo/Reverse Roller Clutch has a issue.
I will give it a shot. Thanks.
I'm hoping that a new filter is what the transmission needs. I'm not going to drive it until I get a chance to replace the filter next week.
It would be great if the transmission had a drain plug (have not checked). That way I could replace half of the fluid when replacing the filter, then change the fluid again with my next oil change. And maybe a third time just for good measure.
According to Ebay there is a drain plug on the 4L60e transmission.
