agreed.
When i converted my 3500 silverado from a 454 big block/700R4 to a 383 stroker with a NV4500, i used a flywheel i found in a junk yard laying in the dirt. Knocked off the sand with a wire brush, and used it as is.
Guess it was warped a bit. Teasing granny gear with 25,000#'s behind me i feel quite a tight spot in the clutch/flywheel. Makes the truck frame tweak and twist as i get rolling. I built the nv4500 with 7.71 granny, and i'm rolling on 4.12' finals on 235/85 16's. It's not a grocery getter. I can make Michigan U-turns in overdrive
Oh well, that was 15 years ago, and 250,000 brutal miles ago. Just hauled in some iron yesterday with it.
OP just needs to put in new OEM stuff and mentally relax.
