Failed transmission removal. What did I miss?
Atlanta
I’m trying to get to the clutch on my Scion xD. The thing is so stiff, it ruined my leg. I was hoping to replace it and see if the pedal got lighter.
I tried for hours to get the transmission to separate from the engine. It would not budge.
I didn’t see any spot on the top of the engine to pry. I only found access on the bottom. I wiggled it, pried, kicked it. I could not get it to separate. What did I do wrong?
I am about at wits end and ready to sell this car. But all that work for nothing is a major disappointment.
Are you trying to pull 'straight' out? If you're pulling at an angle often the friction between the input shaft and clutch plate will simply make removal impossible. Often in the past I've had to lower the transmission side of the engine a few inches to allow me to pull out straight.
On some FWD cars it can be easier to pull the engine and transmission as a unit and work on it with the engine sitting on a pallet not sure if thats your case. Aside from that are you sure all the bolts are out are you pulling straight out you have a transmission jack but are you sure it isnt pushing up and putting pressure on the input shaft.
Give it a try. If the pressure plate is stiff enough it should push it off. Spray the mating surfaces down in hopes of wetting the dowel pins prior to the clutch trick. Let us know if it works.
Yep. All seven. Including starter.
I’m going to try this trick. May as well put my stiff clutch to good use.
I’ll have hard mount points disconnected from the slave cylinder. I’ll try this when I get home tonight.
put compressed air in the clutch slave if that's easier.
After another 3 hours I got it off!
The slave cylinder trick helped! It broke loose some corrosion just enough to help the prying move the transmission.
It took an hour of prying and wiggling, but it’s out!
Now for the juicy details.
Look at that date code! Why on Earth is the pressure plate a 2004 date code? My Scion is a 2010. Did Toyota use a 6 year old Corolla pressure plate on the Scion? The new Aisin pressure plate I got says 2010. Any reason why this could be the case???
Does anything look out of ordinary? What could have been causing the stiff clutch????
Glad you got it! No help on the stiff clutch.
Stiff hydraulic clutch could be the master or slave cylinder. Throwout (release) bearing sticking on the input shafts collar. All of these should be very easy to check now that you have the transaxle out.
Did it get progressively worse as time and miles went on?
I’m convinced it is not either of the cylinders. They don’t leak, don’t have any delayed extension from a pedal stroke, and have consistently been the same stiffness since I bought the car last year.
Pressure plate springs are the most likely reason for a consistent high reactionary force.
But I was hoping to see something obvious, leak heat markings.
