- Joined
- Dec 7, 2008
- Messages
- 5,522
I installed a set of four Monroe Quick-Struts a little less than three years ago on my wife's then-10 year old Corolla. Everything seemed solid and I had no qualms with the build quality of the Monroe parts. About two months ago something in the front end developed a rattling noise, and the steering started feeling a little stiff. My wife also reported a loud clunk when hitting a dip in the road while turning right at a light.
Pulling the top caps off I could see that the passenger-side bearing had a brown plastic shield over the balls but the driver's side did not, and it looked like one or two of them were missing. Not a good sign. I bought two replacement mounts from Amazon, KYBs this time, and planned on replacing them this past weekend. Unfortunately Amazon must have sent me someone else's returned parts because one of the mounts was not correct in the box and was missing the paper instructions. Not at all happy about that but all I really needed was one, so on it went. Luckily everything came apart easily and the new mount swapped on without issue. The alignment seems to be unaffected, the noises are gone, and steering effort is back where it should be. All in all a successful repair.
Interesting-ish thing I noticed. I bought a KYB part in hopes that it would be 'better' but it turns out that both the old Monroe and new KYB mounts use the same exact Japanese-made bearing from the same manufacturer so it didn't really matter in the end. Oh well...
