Did an oil change on an '18 Yukon with the 5.3 EcoTec3 L83 that uses the PF63 variant.
Nothing new here, took some pictures as I waited for the oil to drain and thought I would share FWIW. Wasn't able to cut the factory filter open, I was on vacation and wanted the oil change out the way.
Not so much difference on the outside, although the factory one comes with a red label. I guess both are made by Champion Labs?
Some differences here, of course the E-core had plastic on the inside and the gaps were bigger. Probably would have been better off going with a Fram Ultra for $2 more, something to bear in mind.
Anyone know what the "ZZ" is on the factory filter?
Since this is BITOG, Pennzoil Euro L 5w30 was what went in.
