AC Delco PF63 now replaces PF63E?
Missouri
I am getting ready to change the oil in my 2015 V6 GMC Terrain. From the factory it came with a PF48 filter, which they apparently use at the factory to ease assembly line production, however GMC states that this vehicle requires the PF63E filter. There is a PF63 filter but it was recommended not to use it because of the different bypass valve pressure than the PF63E. Fast forward to 2021, I went to the store and found that they are now only selling the PF63 which is in a different box. I checked around and it seems that the PF63 has in fact replaced the PF63E now. Can anyone confirm this?
This site says it does replace the PF63E.
https://www.gmpartscenter.net/oem-p...lcnJhaW4meT0yMDE1JnQ9c2xlJmU9My02bC12Ni1nYXM=
The "E" means (or used to mean) an Ecore filter, & the PF63 was a "classic" design-metal center tube & end caps. Looks like all the PF63s are Ecore now, and they have the higher bypass pressure rating needed for the newer LS & V6 engines. The Ecore won't hurt it, but I like the UPF filters better, they have a much stronger can than the Ecores do. Edit-technically, the new PF63 IS a PF63E.
According to this link it does look like PF63 #12707246 is the replacement for the older PF63E version.
https://gmserviceinsights.com/new-acdelco-oil-filters-deliver-enhanced-performance/
