Looking at options for adding a transmission cooler to the 2011 F150 in sig. Unfortunately, it did not come with one (other than the in-radiator) from the factory and I'm looking for constructive comments or suggestions. The last time I installed one, all I have to do was cut the return line to the trans, put some flares into it and run rubber hosing to the auxiliary unit mounted up front.
I'm guessing the basic idea would be the same but I am very much unsure of what capacity/size cooler would be appropriate. Or would it be better to look for a scrapyard/used unit? If so does that mean I would need new transmission cooler lines?
