All: I dissected the last 3 oil filters on my 1997 4.6 F150. Im going to compare the Supertech ST2 from walmart versus Motorcraft FL-820S versus Bosch 3410. Im not an expert on oil filters, but I will attempt to summarize what I found in regards to the amount of filter element, construction and materials. Here we go -
First up - Motorcraft FL-820S. The filter element measured 61mm wide, 17mm width, 50 flaps = 61*17*2*50=103700mm2 (1037cm2) surface area. It actually has the lowest media surface area of all the filters tested. Metal caps top and bottom, silicone valve and rubber o-ring.
Second up - Walmart supertech ST2 - The filter element measured 62mm wide, 17.5 mm width, 56 flaps = 56*17.5*2*62=121653mm2 (1217cm2) surface area. Note the number of flaps increased by 6 on this over the motorcraft giving it an advantage in media surface area. Metal caps top and bottom, rubber o-ring and (probably rubber valve - may be black silicone?) [censored] spring versus leaf spring design as on the other filters.
Third up - Bosch 3410 Premium - The filter element is 63mm wide, 18mm width, 69 flaps = 63*18*2*69=156,492mm2 (1564cm2) surface area. Thats 50% more filtering than the Motorcraft & 25% more filtering than supertech. Metal caps top and bottom, silicone o-ring and valve. Leaf spring.
The bosch looked to be the best of the 3. No compromise silicone seals and valves, high surface area and solid spring design. The Bosch comes at a price - it was $9-11 at walmart when the supertech and motorcraft were around $3-4.
Supertech -
![](https://bobistheoilguy.com/forums/attachments/usergals/2017/05/full-19690-7435-supertech1.png)
Motorcraft -
![](https://bobistheoilguy.com/forums/attachments/usergals/2017/05/full-19690-7436-motorcraft1.png)
Bosch premium (black can) -
![](https://bobistheoilguy.com/forums/attachments/usergals/2017/05/full-19690-7437-bosch3.png)
Supertech -
Motorcraft -
