Originally Posted By: RhondaHonda
The ATT signal comes in on the east side in the basement. The house is 6,500 sq feet of finished area on 3 levels so the west side is fairly far ~90 feet away (before accounting for any height differences from floor to floor)from the modem currently. I don't mind spending a few hundred if it means I'll have a good signal all over. I just didn't know what equipment to buy or how to get started. I also didn't realize one good router is any better than the single modem we have now.
Well if you don't mind spending several hundred, get an AC5300 router. Either Asus or Netgear. What's your internet speed? In theory a 5300 router is going to get you 5300 megabits, and you probably only have a 100-300 megabit connection, but it will use more antennas and it's more likely you'll get the full speed at the other end of the house. I had a built in N300 router and I was only getting 2-3 megabits at the other end of the house even though I have a 150 megabit connecting. Even when I'm right next to the router, I was only getting 75 megabits. Once I went to an AC1750 router, I was getting full speed next to router and about 75-100 at the other end of the house. Just use speedtest.net to check your link speed.
