I stumbled on an Eric the Car Guy video where he is saying extended OCIs will cause oil leaks. Yet the engine he is working on and using as an example looks super clean.
I think it has more to do with the type of rubber they use to make the seals. The black gasket in the video looks like a natural rubber type gasket. The replacement blue gasket looks like silicone type gasket which does not become brittle as easily. I know some BMWs have a lot of oil leaks due to the original gaskets being made of buna rubber. A lot of the replacement aftermarket gaskets are upgraded to viton.
Maybe he just picked a bad example to illustrate his point?
Do you think extended OCIs will cause oil leaks or is it just [censored]?
Looking forward to a great motor oil discussion.
