Originally Posted By: joel95ex
I've heard a lot about extended (over 3K miles)OCI's with synthetics, but what about the oil filter and the oil just getting "dirty"? I know this might sound like a newbie question, but even if an oil can withstand the abuse of an engine, it still gets dirty with contamination right? Correct me if I am wrong, but this is kinda why I stick with changes at 3K miles. Am I missing something? I just feel like removing all of the contamintation is the way to go.
Most of the time, the oil is worn out before the filter gets dirty. So, you change the oil. It makes sense to change the filter while you're under there, because it's cheap and easy while you're under there. That's why oil and filter changes usually go together.
Sometimes the filter gets dirty before the oil does. So, you change the filter. You could change the oil as well if you want, but that's up to you; a sump of oil is a lot more expensive than a filter. That's why some people who run REALLY long oil change intervals (10k miles and up) like to change their filters halfway through.
3,000 miles is really short. I can't imagine your oil filter getting clogged in that interval unless your engine is really dirty on the inside and/or your air filter is letting too much dirt in.
As said above, modern engines don't even produce gunk for the filter to catch unless they're busted somehow. Even older engines won't be bad if they're running well.
