I’m not trying to “pull your legs”) I’m not trying to be smart or sound very knowledgeable.
I’m simply sharing my experience and the conclusions I think I’ve made.
I was always talking about my buddies car. I never said it was my car. I even posted in a prior thread about the filter I took off and replaced with the FL400s before these events. I followed up in this thread.
My recent research (I’m not just pulling random ideas out of my head) helped me to acquire my theory for why the filters went into bypass. Absolutely, they were in bypass.
Machinery lubrication has an article titled The Effects Of Water Contamination On Oil Filters for example and they seem to think too much moisture in an oil filter can cause it to clog.
I learned about the probable bypass sitting on those filters and concluded that the transmission probably struggled to create enough pressure to open them at low speeds or rpm’s
As far as my belief that the transmission was was starving for fluid, I dunno, you tell me a better theory.
Perhaps my terminology is not the best. Maybe it’s more accurate to say the car was shuttering at low rpm’s. It didn’t do so at higher rpm’s, it didn’t do so in park but in gear sitting still, initially accelerating and slowing to stop it would do it. It stalled a couple times reversing out of the driveway.
You have a good point in that the fluid has to be present somewhere in the system but it was certainly struggling going back into the pan to be taken back up. The system apparently wasn’t pressuring up enough to burst a line or the filter case or even rip through the media but it was definitely restricting flow enough to cause the events I’ve described. It’s not doing it with the current filter I put on and it didn’t do it before with other filters. Not even with the cellulose filter that initially came with the remote mount he bought.
I do know that a transmission low enough on fluid is gonna struggle and if it’s very low the vehicle ain’t gonna move. I know if the pump is shot and it’s not flowing sufficiently enough, again, it’s gonna struggle.
So whatever, I’m cool with being wrong if I am or not fully understanding what’s going on but I don’t think it’s it cool to have my character attacked because of it.
If you have knowledge to share you could probably do so without contention and still feel good about yourself.
Regarding the stuttering/sputtering effects, I remain skeptical, but I'll take you at your word for I have no ability to prove otherwise.
Let's approach this from your perspective. You want to know if enough moisture is in the air that it will cause a cellulose oil filter to essentially blind off the pores? I rather doubt it. That would infer horrible consequences for nearly any filter which sits on a shelf at any dealership, service center or John Doe's garage anywhere it's "humid" (essentially anywhere that isn't the desert southwest). Yet we never hear of oil filters failing due to their celluose media absorbing atomspheric water. So I doubt the air is supplying enough moisture content to make a filter fail in the manner you describe. I store some of my filters in my barn; it gets super-humid in summer around here. I also cut open my filters after use; always curious to see what I can find. I've never come across a cellulose media so swelled from water that it couldn't pass lube. I find that premise difficult to swallow; that the moisture in air is enough to essentially make the media swell shut, for a lack of a better word.
Perhaps the moisture is actually in the tranny fluid? If that is the case, the using the celluose filters is actualy beneficial to your application. Use several of them, and they will eventually get the moisture out of your system. Using a syn media filter won't do squat to remove the moisture; it cannot aborb anything in the media itself.
You said it yourself ... the cellulose filter was OK for about a day, and then problems started happening. I doubt the filter was contaminated from sitting around; it probably got water in it from the tranny fluid. If your fluid is heavily contaminated with moisture, it may be a good idea to just do a couple drain/fill cycles before going through several filters.
And, take a UOA of the fluid and see what that tells you as well.
