So I had put an old Fl400s on in-line adapter for a transmission.
Everything was fine for about a day then the car started idling hard and seemed to be missing out at low speed. There was no engine light.
Thought it was do to a vacuum leak I found but that didn’t fix it.
Cleaned mass air flow sensor and took off throttle body and cleaned it. Still the same.
Plugs and wires and pcv were all recently done already.
Finally I felt the external transmission filter and it was cold to touch after a good highway drive. Took it off and put a different old old filter on (ph3600) it was all good at first and was hot to touch after driving. That lasted less than a day and that filter apparently started going into bypass too as it was now cold to touch after a good highway drive. Got the same results at that point.
Went and got a new big wixxp 51515 and all is fine.
The Fl400s and ph3600 had both been out in my garage for a couple years or so.
My belief is that the cellulose medias in those 2 filters obtained moisture while sitting around for a long time and were forced to go into bypass in short order when put in use.
The bypass relief pressure setting must be something like 8 to11 and is apparently too high for the transmission at idle speed.
The wixxp is a synthetic media and is big so it won’t need to bypass.
That’s the lesson I learned recently.
I think cellulose filters should not be used if they are old or exposed to high moisture(humidity).
Used to filter motor oil at higher psi than a transmission can put out, they could very possibly be bypassing the whole time and you wouldn’t know it I think.
