Experience with Redline Oil???
Hello,
sorry but you are quite wrong concerning the capital T!
The Mobil 1 0w30 lubricant was not used by either!
Mobil 1 15w-50 has proven to be a very suitable racing lubricant "un-tweaked" in many engine families. Especially those used in short events where fuel dilution is not a major consideration!
Un-tweaked Mobil 1 0w-40 has been a favorite race oil in the International Porsche community for several years
Well Belvedere, I believe the single most revealing bit about all you've posted is that when asked to bring the tech, all you can do is cut and paste manufacturer's marketing materials.
Not only that, you seem to have a great deal of trouble actually reading anything. After you repeated failure to bring a clue to the discussion, I post an absurdly long compilation of typical engine oil temperatures. Your response to that, "Engine coolant temperature (liquid to solid thermal transfer) is not the same as engine oil temperature" is frankly just bizarre.
To compound it,you then post this "You can have a perfect engine coolant system and still destroy your oil". If it rhymed, I would have suspected Dr. Seuss wrote it. By the very definition of what an engine coolant system is supposed to do, if you're cooking your oil because your engine is too hot, something is not "perfect"
You seem to be straying from amusing dolt to irrational nut, and I have to admit my interest is waning. But just for old times sake, I'll give you one more chance to actually show you know something other than what the salesman told you.
For your "race" oils -
* what chemical properties do they possess different from "street" oils that allow them to "protect the engine at all cost"
* what are the side-effects of these properties, i.e. why can't street oils do it to?
* Why can an API, ACEA, or manufacturer approved oil possess the same properties?
Good luck with that, I look forward to your utter and complete failure to offer any actual technical information whatsoever. But I do hope you come up with some more clever pejoritives for me this time, your usual ones have lost their novelty.
Originally Posted By: Doug Hillary
Hello,
I could be wrong but from my recollection the Porsche team ran Racing 0w30 (for qualification) and Mobil 1 15w50 until Mobil discontinued the 0W30 in 2006. After which, they ran Mobil 1 0w40. Again, I could be wrong.
You are as helpless as you have stated previously. Why do you think your coolant can last 100k while you have to change your oil every 5-10K miles? With a perfect engine cooling system you can destroy your oil with compression blow-by. Do I need to tell you the temperature of the combustion flame or can you look it up yourselves? I am wasting my time here since you haven't a clue how an automobile engine works.
As expected, no tech from Belvedere, but I was kind of hoping for a little creativity in the insults.
While disappointed, I will grant the title of "King of the non-sequitors." When previously did I or anyone else bring up the subject of engine coolant change intervals? When was an OCI of 5~10k miles discussed? Funny how when asked a direct question, you only seem to be able to provide answers to unrelated questions nobody asked.
Yes, you are definitely wasting your time here. Because, if by some miracle, some fact or tidbit of technical knowledge manages to embed itself in your few working synapses, it undoubtedly can only do so by booting out something else from your poor tiny overworked brain with a resultant loss of control of bodily functions. So before an unfortunate and messy accident occurs, you really ought to put on a fresh diaper.
Back to your trolling mode eh?
Hi,
azsynthetic - you said this;
"I could be wrong but from my recollection the Porsche team ran Racing 0w30 (for qualification) and Mobil 1 15w50 until Mobil discontinued the 0W30 in 2006. After which, they ran Mobil 1 0w40. Again, I could be wrong."
You are!
Where is the Redline content????????????????????????
My new (used) BMW will be running Redline gear oils and p/s fluid possibly engine oil. I know many race teams sponsored by major oil companies use Redline behind their backs. Traco used to supply all the engines to a series I in the U.S and when they came back for rebuild they could easily tell which ran Redline. Redline (and NEO) are used by many European and American race teams. My Outback never ran as well as it did on Redline eng oil and it still has all Redline gear oils. It will do me
Back to the subject at hand, Redline motor oil with an emphasis on use in BMW’s. Since no particular use was mentioned, the default assumption is that the intended use is for standard engine in as street driven car.
Here’s what we know as undisputed facts about Redline
• It is not API approved
• It is not ACEA approved
• It is not BMW approved
• It is not MB, Porsche, or any other manufacturer approved
These approvals are best looked at as a source of information. Having an oil be API approved means it has been subjected to a specific and defined battery of laboratory and engine tests. The approval tells us the oil’s demonstrated performance meets or surpasses the defined minimum standards. Likewise, ACEA approval provided information about an oils demonstrated performance to the defined standards for a similar battery of laboratory and engine tests. Manufacturer approvals take this a step further, enhancing the requirements of specific laboratory test results deemed most important to the engine manufacturer. Engine tests are also performed using the manufacturer’s own engines with performance requirements dictated by the manufacturer. While it is not necessary to have one or more of these approvals to produce a high quality engine oil, they do serve clear indicator of what performance you can expect from an engine oil. With the approvals, you have some specific and reliable information. Without them, the lack of information provides only uncertainty. You are free to put as much or as little concern as you want upon this uncertainty, but its presence is indisputable.
So absent any third party approvals, the available sources of technical information about Redline consists solely of the following:
• Technical information provided by Redline
• VOA’s and used oil analysis such as posted here at BITOG
Since the original context was in regards to BMW engines, I’ll limit the analysis to the two most likely grades to be used in an unspecified BMW engine, the 5W30 and the 5W40. Here’s the key viscosity data as available from Redline:
• 5W30
o Kv100 – 10.6
o Kv40 – 62.0
o HT/HS – 3.8
• 5W40
o Kv100 – 15.1
o Kv40 – 94.0
o HT/HS – 4.6
Since we considering using this in a BMW, let’s look at this compares with properties of oils that are BMW approved. Based on a compilation of 60 oils known to be BMW LL-98, LL-01, or LL-04 approved, the following properties are evident:
• Kv100 – average of 13.0; range is from 11.3 to 14.3 (60 data points)
• Kv40 – average of 76.7; range is from 63.6 to 93.0
• HT/HS – average of 3.7; range is from 3.5 to 4.0
As you can see, the kinematic viscosity of the Redline oils is not just significantly different from the BMW approved oil average, they actually fall entirely outside the range. The strong HT/HS performance of the Redline oils is notable, but whether or not it is sufficiently offsetting of the other properties would be an individual judgment call based on one’s particular application and needs.
Based on 7 Redline VOA’s and 5 used oil analysis found here at BITOG, we find the following:
• There is a lot of Moly in Redline, 4~5 times that of any comparable grade oil with any sort of official approval
• At 5,246 miles in a Honda engine, the 5W30 showed elevated iron and copper levels, viscosity has lowered to a Kv100 of 10.1 and a Kv40 of 56.3
• At 10,000 miles in a Ford engine, the 5W30 showed elevated iron and lead levels (lifter and camshaft work was performed at 7k), viscosity has increased to a Kv100 of 11.8
• At 3,880 miles in a modded WRX, the 5W40 showed somewhat elevated iron and lead levels for the amount of mileage, viscosity has lowered to a Kv100 of 13.3
The moly level could be a source of concern on two fronts. Depending upon which type of moly is being used (and this is not disclosed) there is a possibility of accelerated bearing wear. Also, there is likely to be a higher sulfated ash level (again, there is a lack of data here) which can have consequences in higher piston and combustion chamber deposit levels and higher particulate emissions. Again, you are free to decide how much importance to place on this information based on how closely it correlates to your particular application and needs.
The remaining sources of information are:
• Marketing materials provided by Redline
• Anecdotes, pro and con, about people’s own direct experience
• Hearsay, pro and con, about other people’s experience
As it turns out, Redline seems to be a big fan of Redline, and that is reflected in their marketing materials. There are a lot of broad categorical statements, but no specific supporting data is provided. People’s direct experiences seemed to be mixed bag as well. Some users report problems, some report miracles, it’s up to you decided the relative credibility of each report. Finally, there are the claims, frequently little more than just rumors, about how so-and-so or such-and-such use Redline. The results reported are essentially always limited to very broad generalities free of any technical details. While I’ve never been much a bandwagon guy myself, you are still free to place whatever value upon these stories you deem appropriate.
The common theme here is that it’s your engine, your choice. Look at the information that is available, consider the possible importance of information that is not available, listen to the opinions of those you deem credible, and decide for yourself what’s appropriate for your application and needs.
• 5W30
o Kv100 – 10.6
o Kv40 – 62.0
o HT/HS – 3.8
• 5W40
o Kv100 – 15.1
o Kv40 – 94.0
o HT/HS – 4.6
I think we should also compare the zinc levels of such oils. Redline's compared to some LL approved. If the zinc levels are not present you will not get your extreme pressure protection that is needed.
I haven't looked at Redline so I really don't know their levels.
Anyone looking at running Redline in a BMW should spend some time on the BMW forums. Some have had luck, some have had swollen seals and leaks.
Zinc levels seem to be in mid- to high- range, about 1300 to 1600 depending upon the particular flavor.
Phosphorous levels are at the high end of the scale, running about 1200 to 1400.
Calcium levels are solidly mid-range at about 2400 to 2900
There have been studies done that show too high of ZDDP levels are actually a bad thing. Again, the "more is better" philosophy just doesn't always apply at all. Most modern engines don't need those levels of ZDP from what I have read. Flat tappett cams can benefit from higher levels of ZDP however.
I agree that too much is not necessarily a good thing. That's why I was more interested in how it compared to LL oils.
I think BMW and VW TDIs still need it. Their approved oils seem to have a little higher zinc than the non-approved oils.
With the exception of calcium levels in some of the LL-01 oils, all those additive levels are higher than anything I've seen in a BMW approved oil.
Just to make sure I'm following you....
Additive levels in the Redline are higher than the LL oils?
Want to make sure I don't misunderstand you.
Thanks
Yes, that's correct, the Redline additive levels are higher than the LL additive levels (with the exception of calcium)
Bear in mind though that the dataset on additives in the LL oils is limited. While I've got data from 50+ VOA's/used oil analysis on LL approved oils, from Mobil, Castrol, BMW, Elf, Pentosin, Motul, and Shell, it's still an empirical observation rather than a technical definition of requirements.
Originally Posted By: jaredyost
jpr said:
Back to the subject at hand, Redline motor oil......................................................
.......Anyone looking at running Redline in a BMW should spend some time on the BMW forums. Some have had luck, some have had swollen seals and leaks.
Good point should not be taken lightly, there are posts that confirm weeps or leaks after Redline motor oil has been used. The affected owners reported it only happened with Redline synthetic oil and not other synthetics, and were quite clear it was NOT because a false seal was uncovered.
