- Joined
- Sep 2, 2016
- Messages
- 984
What are your thoughts on the excess glue on the base plate of these Wix (Mexico) filters? I ended up returning them.
Unacceptable lack of quality control. I wouldn't buy WIX, especially with it's poor efficiency.
Good decision returning them.What are your thoughts on the excess glue on the base plate of these Wix (Mexico) filters? I ended up returning them.
Not sure when/where those figures derived, but the previous design (before M&H owners) used Wix thread end bypass piece which did occupy significant space in canister. Most noticeable on smaller filters. Newer Wix design M&H going to, dome bypass with flat stamped spring likely significantly more media area. Also, the Wix equivalent of the Fram 7317 is the 57356. The one shown is actually the 9688 equivalent. But, old specs/design the area difference would hold true..I recently learned that their filter media is quite a bit smaller than the competition too. Eg:
Fram PH4967: ~80 sq-in
Wix 51394: 47 sq-in
Fram PH7317: ~102 sq-in
Wux 57092: ~67 sq-in
Good Morning Pepe Silvia,What are your thoughts on the excess glue on the base plate of these Wix (Mexico) filters? I ended up returning them.
Bigger point for me, not keen on the coo change. Seen other examples of M&H moving production from US to topic coo, with quality suffering.
+1...but does any message regarding QC or bad handling or customer dissatisfaction ever go upstream?Good decision returning them.
Thank you for the posting.
If the filters came from the factory this way;
My first thought was what is glue doing in that area? The anti drain back rests on the mounting plate and is held in place under spring loaded pressure. My second thought was lack of leadership in driving manufacturing excellence and a quality culture. Clearly this defect was seen by many in the process and they were still put into boxes. I'm glad you returned them.
I noticed the boxes in the background look kind of beat up. Did you get these via mail order or at a retail store?
Used many of the Napa Gold 7356 version of the 57356 (same filter) on Hondas. That was back when my local Napa store had semi-annual NG 40% off sale. Always completely satisfied with the results. Never a concern about media area, more than enough holding capacity in a well-maintained vehicle. Also, unlike topic, they were made in US in Gastonia NC. That said, the 51394 pictured above looks ok to me. Like it got the job done.My apologies, the ~67 sq-in figure was indeed for the 57356 and not the 57092. The 57092 filter media is ~116 sq-in. I noted these figures from Whip City Wrencher videos and other sources that may be dated now.
And you are correct. The old bypass valves took up a significant amount of space.......
It's to seal between the base plate and the piece of metal that holds the base plate gasket. You can see the glue seal also on the photo from the ADBV side in post 10. The filters in post 1 just had a little too much glue applied, and it oozed out when assembled as seen in the photos in post 1.If the filters came from the factory this way;
Cut and post that sucker when you’re done with it.I have just peeled the excess glue away and installed the filter.
