EXCELLENT Particle Count with E-Core Supertech
High in the Mountains of Central California
I know this is a used oil analysis, and that the wear element numbers suck, but I am posting it here in the Oil Filter forum so you can see the excellent particle count, and frankly, I'm too lazy to type it in.
Background: this was a 1500 mile OCI, and for the last 800 miles, I used a MASSIVE LC20 dose. I also had a fuel system problem and several bad flooding incidents, so I got nervous about fuel contamination, and changed the oil. When I cut open the E-Core, there was a lot of grit and some BIG chunks of "carbonaceous deposits," yet look at that particle count!
I'm sold on the E-Core, at least the Supertech version.
Is the "E Core" a new feature on the Super Tech filters?
I have recently purchased 2 Super Tech 3600 Filters and I don't see anything about "E Core" on the box... How can I tell if the filters I have are the E Core ?
I don't know if it would retain that low number ..but even if it just retained the ratio for the miles ..that would be a decent PC, IMO
That would put it not too far behind my 9k PureOne PC (if it can be figured that way
- approx numbers used)
>2 micron = 1,666, 2500(daves)
>5 mu = 617, 900
>10mu = 170, 265
>15 mu = 66, 100
>25 mu = 15, 24
>50 mu = 1,
>100 mu = 0.
Boaz..look inside the filter down the center tube. If it's a metal tube, it's not E-core. It you see a plastic cage, it is E-core.
Only certain part numbers are E-core within the Super Tech ( and other private label Brands) line.
