Examining used spark plugs
Gilbertsville, PA
Use your expertise to help me learn from these used spark plugs. What jumps out at you? I don't see excessive deposits or gunk on the electrodes but they are fairy dirty. Just pulled them from my daughter's 2016 Passat with the 1.8T engine. They are NGK by say Volkswagen on them too. This is at 82,000 miles and I'm not sure if they were ever changed before. My guess is no. I bought this for her used at about 70,000 miles. I replaced with identical aftermarket NGKs.
Mine looked far worse, but still there was no performance issues at all.
These days there is very little you can tell from spark plugs and even less you can do about it, if something looks off. Back in the carb days it mattered and you could adjust the mixture to your linking, these days no such thing is possible.
NGK Laser Platinum #06k905601dk2
Laser Platinum are dual electrode, really good stuff.
I would run those out to past 100k I think and running some Fuel System Cleaner will help clean up the injectors, combustion chamber including the spark plugs. Valvoline Restore and Protect might also help if you're having any misfire or oil consumption.
Engine is running great, but I do want to run some fuel system cleaner for the injectors…
If that’s what you want to do, do it during the final 2 fill ups before an oil change. That way it gets all the chemicals out with the old oil. But seeing your plugs I wouldn’t. They are burning beautifully. You have a keeper there.
that's way too many miles for platinum plugs, especially in a turbo engine... you can see how worn/rounded the electrodes are... with iridiums that's OK with that many miles but you'll end up with the same looking plugs if you get them to 100k, which is way too much on a turbo engine
not on a turbo engine it's not
combustion pressures and temperatures are much higher, and that requires higher spark voltages... higher spark voltages + heat + pressure = faster wear
these OEM denso iridiums came out of a toyota 1ZZ-FE at 105k miles.... USDM recommended intervals is 110k... it ran fine but after seeing that, it's way too many miles for it... even 100k is stretching the limits of what they can do with the platinum ground electrodes that are basically gone, in a bone stock non-turbo engine!
