That's because people go for what they know and think they understand, or their neighbor / friend / mechanic recommends. There is nothing wrong with Idemitsu, it's good stuff.I picked up several jugs of this last year for $10 each. Was on the bottom shelf at AZ. Dusty, hadn't been touched in a year. Has the important certs. I think it is OE fill for several Japanese brands.
No varnish, just trying to maintain the engine with a variable OCI. Sometimes 3k/6 months sometimes 1k/12 months. Not my rides, so i cant effectively put it into a consistent OCI.What's your application?
The oil with the best anti wear and cleaning capabilities is made by @High Performance Lubricants without question. They also make a unique 0W-20 with a VW502 additive package, called the Supercar "OVERKILL" 0W-20. There is truly nothing like it.
If you want to buy something off the shelf, then get Mobil 1 EP 0W-20. It cleans pretty decently.
If you want something with a MB229.71 approval that also claims ACEA C5/C6 and can be run in something like a Toyota Supra or Land Rover engine and it doesn't cost an arm and a leg then get Castrol EDGE EP 0W-20.
HPL also makes an MB 229.71 ACEA C5/C6 oil called the 0W-20 Euro.
If you have a varnished up engine and you want to clean it up, then there is no better oil than HPL for the job.
HPL has gained some notoriety, but recommending such an expensive oil is basically grounds for an immediate nogo. Mobil 1 EP or Castrol Edge probably would gain some consideration
You asked, so we replied. You wanted a trusted brand that doesn't focus on marketing. HPL is that brand.What are some trusted, less marketing heavy 0w20s?
Here you go, the cheapest brand name 0W-20 at this time:HPL has gained some notoriety, but recommending such an expensive oil is basically grounds for an immediate nogo.
I thought that 0w20 doesnt meet euro spec?You asked, so we replied. You wanted a trusted brand that doesn't focus on marketing. HPL is that brand.
I easily found HPL 0w20 oils but I did not see the one, "Supercar "OVERKILL" 0W-20" when searching thru the HPL pages. Can someone send me the link / title to that page? Maybe I was not looking in the corret pages. Since I pay off cars within the first 12 - 18 months & like to keep cars as long as we can, I may decide the prices of the HPL is worth it to me since I do not plan to make any car note payments for as long as I can keep current vehicles alive. Keep them garaged and so clean I had someone ask about a month ago of the 2009 Honda "is that a new car?" and then "Oh, I see you must have had it repainted?" They get washed and waxed so often they do look freshly painted. Collinite or Meguiars brands are what we use. In addition to OilChangeDelusions I also suffer from OverdoingCarDetailing!What's your application?
MB-Approval 229.71 |
Porsche C20 |
VW 508 00 |
VW 509 00 |
Which one is better Castrol edge with MB 229.71 or ESP X2?Castrol Edge 0W20 has MB229.71.
Are they not rated the same? I thought last time I looked them up they both held the same ratings on their web pages? Did something change recently or you making a point with someone I missed a few posts back?Which one is better Castrol edge with MB 229.71 or ESP X2?
I’m sure there is some kind of difference between the Castrol and Mobil with those same specs. That’s why I am asking edyvw. He will know for sure. I think he was stating that regular edge 0w20 had the MB229.71.Are they not rated the same? I thought last time I looked them up they both held the same ratings on their web pages? Did something change recently or you making a point with someone I missed a few posts back?
Mobil1 IMO.Which one is better Castrol edge with MB 229.71 or ESP X2?
I tried Castrol Edge 0w20 two oci in a row. I had run Castol in other cars in the past. For some reason I could never make myself stick with it. Probably some foolish thing like "I dont like how black it gets thru an oci or something silly like that." I do remember it made one of the cars engines sound like a noisy played out sewing machine until I switched to something else. Oh yeah, that one I ended up for years after that with Royal Purple 5w20 until I got rid of it with 185,000mi a few years back.Mobil1 IMO.
