Originally Posted by DoubleWasp
Ok, so this manual trim wheel is literally a mechanical connection of some sort dependent on sheer mechanical force to operate?
yes
With the KC-46, does that mean that a pilot who had to "fight" the MCAS would automatically and permanently lock out the system just by grabbing the yoke and giving input?
yes. This is called the "yoke jerk" method of turning electric trim off. "Much like tapping the brake pedal in a car to disengage cruise control, a sharp tug on the controls of older models of Boeing Co's 737 used to shut off an automatic trim system that keeps the plane flying level, giving the pilot control. But Boeing disabled the "yoke jerk" function when it brought out the 737 MAX, the latest version of its top-selling jet — and many pilots were unaware of the change, aviation experts told Reuters." -- https://graphics.reuters.com/ETHIOPIA-AIRLINE-CONTROLS/0100916V1NZ/index.html
Possible the ET302 crew put the switches back on to try to recover with electric trim realizing they weren't going to win against resistance using the mechanical trim? Situation looked even worse, so try turning the system back on to recover before MCAS cuts in, and then shut it back off soon as it tries?
Likely, from the looks of it.
Uneducated hypothetical: Would opening the flaps and speedbrakes have arrested their over speed issue and locked out MCAS while giving them back electric trim, or would that have just opened a whole other can of worms?
Flaps would be ripped off at those speeds, maybe speedbrakes too. Flap deployment does turn off MCAS normally though.
Actually, if they would have turned ON the Autopilot, they would have been saved since MCAS turns OFF when autopilot is on. I think on this system the autopilot could stay engaged with AoA disagree, for speed on pitch modes, for example, or vertical speed mode, where the feedback control system doesn't use AoA.
yes
