So are ALL gas station/companies required by law to mix in a greater proportion of ethanol in their gas in the winter months?
I use Shell Optimax Gold 91 here in Ottawa. Am I correct in presuming that in the spring/summer, Shell does not put any ethanol in their gas?
If what you all are saying is true, then it's probably a combination of lower ambient temperatures together with an ethanol blended winter gasoline that's causing increased fuel consumption.
With regards to the temperature sensor, someone mentioned that it makes the fuel/air mixture to become richer with a decrease in ambient temperature. What is the advantage in this?
Regards,
AJWan
