I'll give you an example
My Briggs and Stratton mower, I ran
This 5W20 over winter (never got cool enough that the grass really died off), and wasn't happy with the hot knock that it had on restarts.
Thought I'd do an experiment, and take the oil temperature (type K thermocouple down the dipstick), and after mowing, 10 mins free revving against the Governor, and at 4C, I got 87C oil temperature.
Using the
Widman Calculator gives 11.4cst at 87C.
To bookend the experiment, I put
Thsi 20W60 in it. If I could have got a 25W70 on the day I would have.
Same experiment and at 4C it ran to 97C...the oil was taking more work from the engine, and in order to clear that to the atmosphere, ran 10C hotter. According to the viscosity calculator, that's 26.24cst.
The "self compensation" isn't linear, it doesn't self adjust to make the viscosity in the bearing, and therefore the MOFT, the same under all conditions.
The OEMs supply their minimum oil pressure recommendations to establish the mechanical integrity of the engine on their recommended lubricants, not as a viscosity selection tool...Oil pressure never has, and never will tell anyone about the MOFT in an operating engine.
