Engine vibration after rebuild
Hi everyone. 09 Pontiac vibe/2.4l 2az fe engine. I mentioned this in an earlier post, but I wanted to be more concise. My engine vibrates from 700 rpm to about 1100 rpm under any condition - cold/hot, in gear/in park/while driving. It is perfectly smooth above and below that rpm range. I can best describe the vibration as fast, even, and steady. I can see the engine vibrating, and while it's not moving very much at all, the vibration is intense and resonates throughout the car causing a loud, low-pitched hum. The engine used to vibrate all the time due to a bad motor mount and the new mount seemed to correct the problem, but I've recently noticed this oddly specific vibration. It may or may not be related to the new mount, I have no clue. Any ideas? Here's a picture of the old mount if it helps:
Hi everyone. 09 Pontiac vibe/2.4l 2az fe engine. I mentioned this in an earlier post, but I wanted to be more concise. My engine vibrates from 700 rpm to about 1100 rpm under any condition - cold/hot, in gear/in park/while driving. It is perfectly smooth above and below that rpm range. I can best describe the vibration as fast, even, and steady. I can see the engine vibrating, and while it's not moving very much at all, the vibration is intense and resonates throughout the car causing a loud, low-pitched hum. The engine used to vibrate all the time due to a bad motor mount and the new mount seemed to correct the problem, but I've recently noticed this oddly specific vibration. It may or may not be related to the new mount, I have no clue. Any ideas? Here's a picture of the old mount if it helps: View attachment 49167
Check the mounts but as the poster said this would be a serious contender for this issue.
Would there be any other symptoms if the balance shaft timing was off? Would it only cause vibrations in such a narrow rpm band? The guy who rebuilt my engine mentioned not knowing how to set up the timing and he would have to get someone else to do it.
Also, I just read another symptom is a "buzzing" sound and my car makes kind of a nasally eeeeeh sound when accelerating that sounds similar to power steering whine.
Last time we had someone that had a buzzing while driving and idling it was the ABS Module had went bad. I would check the balance shaft timing first though.
