As some may know, I had a shrimper that had a somewhat lazy mechanic do some work on his engine.. basicly, fixed the symptom,replaced bearings on overhead cam, but failed to find what caused the problem, oil sump screen clogged up with gasket material and old wire ties and such. So, after 5 times of repairing this motor, without ever pulling the pan, I was finally able to convince the shrimper to allow me to pull it, which we did, and found the cause of the problem.
Now, due to this garbage floating around, his engine broke a ring on the #4 piston, so here he sits with his engine torn down.
This engine has been running schaeffers for approx 5yrs, and in the last year, I convinced him to use our diesel treat 2000 fuel additive.
Here is some pic's of the piston and head so you can see for yourself the carbon or should I say the lack of carbon build up on these parts. Also, none of the piston rings were stuck nor was there any carbon deposits on the backside of the rings.
