Below are 5 oil analysis reports of G-Oil from:
(1) Petroleum Quality Institute of America (VOA)
(2a) Wear Check (April VOA)
(2b) Wear Check (May VOA)
(3) Wear Check (Oct used oil analysis - Overheated Engine)
(4) Wear Check (Nov used oil analysis)
G-Oil VOA's have been controversial. The PQIA virgin oil analysis (sample #1) posted below appears at URL:
http://www.pqiamerica.com/January2012A/January2012R2/goil.htm. In April of 2012, I submitted a VOA sample (#2a) to Wear Check and received questionable results that did not match the PQIA analysis.
In May, I asked Wear Check to retest the original sample that I had sent to them. The results (#2b) were closer to that measured by PQIA. This produced a storm of controversy in this thread:
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2612937#Post2612937. Other VOA's of G-Oil with different formulations have appeared in this forum (i.e.,
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2740477#Post2740477).
My October used oil analysis sample (#3) below was obtained following a coolant leak. On October 3, 2012, I stopped for a gas fill-up, noted the mileage and proceeded onto the highway. There was nothing amiss during the fill-up. 14 miles later, I noticed the engine overheating and pulled over. A coolant hose had burst and steam rose from the engine compartment. At that point, the G-Oil only had 493miles on it. After making repairs, I completed my trip home and submitted a used oil analysis with 940 miles on the oil. Sample (#4) was the new oil that replaced the overheated sample (#3) and has 943 miles.
A comparison of samples (#3) and (#4) contrasts the overheated oil (#3) with non-overheated oil (#4). Both are used oil analysis.
Code:
SAMPLE (#1) (#2a) (#2b) (#3) (#4)
SAMPLE TYPE VOA VOA VOA used oil analysis used oil analysis
MILES 0 0 0 940 943
Jan April May Oct Nov
WEAR WEAR WEAR WEAR
CONTAMINANT PQIA CHECK CHECK CHECK CHECK
Silicon 4 6.5 4.6 9.2 5.8
Potassium 8 24 0.0 0.0 1.6
Sodium 10 5.3 3.4 9.8 3.9
Fuel (%) --
Glycol -- -- -- -- --
Water (%) --
Soot (%) -- -- -- 0.1 0.1
Sulfation -- -- -- 83 87
Nitration -- -- -- 8 8
April May Oct Nov
OIL WEAR WEAR WEAR WEAR
CONDITION PQIA CHECK CHECK CHECK CHECK
Boron 215 358 227 64 75
Barium
Calcium 1966 3782 2374 3895 3938
Magnesium 8 21 11 8.0 13
Molybdenum 74 113 72 113 124
Phosphorus 676 1247 787 835 855
Sulfur 2695 5291 3142 2559 2589
Zinc 762 1257 843 954 941
Visc@40C 54.9 55.78 55.78 -- --
Visc@100C 10.0 9.77 9.77 9.73 9.75
VI 172 161 161 -- --
Oxidation -- -- -- 119 128
TAN -- 1.44 1.44 1.74 2.05
TBN 7.2 -- -- -- --
April May Oct Nov
WEAR WEAR WEAR WEAR
WEAR PQIA CHECK CHECK CHECK CHECK
PQ -- -- -- -- --
Iron
Nickel
Chromium
Titanium
Copper
Aluminum 2 3.7 1.7 7.0 4.4
Tin
Lead
The amount of contaminants, such as silicon and sodium, are higher in the overheated oil (#3) than in the non-overheated oil (#4). Wear indicators, such as the amount of metals, appear slightly higher in the overheated oil (#3) than in the non-overheated oil (#4).
