Engine oil recommendation for Kubota MX6000 tractor
....I run 10w-30 in my two Grand L series Kubotas and have had no issues for 20 years of operation.
I was thinking more along the lines of a 15w40 as this one has a turbocharged ~63hp engine in it, but like you say, it would probably live happily on a 10w30 HDEO as well.
I run 10w-30 because I do use mine to clear now in winter and I want the slight advantage of thinner lube for the starting ease. I don't have turbos, but even if I did, I'd still use 10w-30 for the winter starting issue. However, 15w-40 would also suffice quite well, IMO. I cannot find any reason to think that either would have any wear protection differences. I've run a few UOAs on mine over the years and found nothing but desirable results.
I use mine year round as well. I do find it starts with a little less effort when running a 5w-40 or 0w-40 when very cold. My first year with it was a stinker as it would not start in single digit temps. And it was brand new! Turns out the battery was not very strong, didn't have a block heater and the 15w-40 was a little thick.
Since that MX6000 has a DPF, I would be using a low SAPs synthetic oil rated for diesels to keep it from getting plugged up with sulfated ash. Plus, being a northern climate with year round use, a 0W or 5W (W=winter) rated oil is recommended for cold oil flow and easy starting. I would use the same thing I run in my 2012 BMW X5 turbo diesel (tuned, 350 HP, 515 ft-lb tq), which is Mobil 1 ESP 0W-30. It is at the top end of the 30 weight viscosity scale (12.0 cST @ 100C) and is an excellent all-around full synthetic motor oil for diesel and gasoline engines (search the forum for other's opinions as well). I run it in my daughter's BMW X3 with the N55 turbo gasoline engine as well. Plus, you can get it at Walmart for ~$27 for a 5 qt jug.
Kubotas dont care. I would not run less than 10w30.
Not sure of the engine model but that’s consistent with our generator service Kubota diesel.
We run SAE 30 in tropical service but I’ve thought of going to 10w-30 even there.
