Engine oil for OMC Cobra engines
Germany
Hello,
still confused about the selection of marine engine oils and all the "recommendation" in the internet, I am trying to find the best solution for my boat.
The manual of the 1995 OMC Cobra 4.3GL calls for streight weight SAE30 and not for multiviscosity oils.
Nowadays I can just find marine multiviscosity oils e.g. Quicksilver, Sierra, Ravenol, Rowe and Kroon Oil in the viscosity 25W-40 and 20W-50.
I know, today oils are much better than 1995.
The 20W50 and 25W40 are thick oils, but do they stay in grade and are they comparable with the SAE30?
Btw. I live in europe, so some oils are not available here.
Are there some recommendations for a usable oil for ths engine?
If you are worried about 20w50 shearing, change it more frequently. I would talk to some local marine engine techs to get their input. No experience with old boats, just old BMWs
Originally Posted by CT8
Yes and the 15W4-40 HDEOs work well in marine use.
+1
Your biggest issue will not be the engine, but rather the outdrive. Mercruiser are easy to find parts for, OMC, not so much.
It's a small block Chevy. Other than running at high RPMs often,
not much different than the auto/truck engine.
15W-40 available everywhere.
My 2¢
+1
It's an SX, so all Volvo Parts will fit.
I have been using Rotella 15W40 for the past eight years on my 2455 Bayliner. It has a five liter GM engine and OMC outdrive. I was surprised how clean the oil looked when I changed it this fall. Sure sign I didn't use it enough!
Same here.... Rotella 15w40 or Chevron Delo 15w40 for many, many years
Use whatever European 15w40 (or similar) HDEO you can find
