I was looking at the wiring diagram for the 1984 Cavalier to see if I could upgrade to a cluster with a tach. The answer is yes, but I'd have to re-pin the cluster connector and add a tach wire.
I noticed that there are actually TWO temperature sensors on the engine. One is a regular temperature sender (either a switch if it only has warning lights, and a thermistor if it has gauges--this car only has warning lights, which is why it has no tach), and one is an "engine metal temperature sensor" which is a switch that will make the gauge peg out (or turn on the warning light).
I suppose the engine metal temperature sensor is there to make sure that an overheat condition is indicated even if all the coolant is gone from the engine, since my understanding is that a regular temp sensor could read normal or even cold if all the coolant is gone.
The only other vehicle I know of that has something like this is the Crown Victoria, where it's used by the PCM to put the engine into overheat mode where it runs on alternate cylinders.
Doesn't seem like most engines have a sensor like this, so if all the coolant has left the engine, a driver wouldn't know the engine is overheating.
