Originally Posted By: boostedtsiawd
I took it to a mechanic and he said its coming from the fan and i would need to replace the fan clutch. When i rev the motor you can hear the roar but when its just idling nos ound so this is not normal for it to roar when reving or accelerating?
If you hold the engine about 2,000rpms the fan roar should disappear. If it still roars the fan clutch went into failsafe so it's stuck engaged. It's normal to not hear the fan roar when idling because the fan isn't spinning as fast.
