ZGRider
Originally Posted By: Jimbo
Originally Posted By: ZGRider
1. Is the engine air-cooled or liquid-cooled? (heat breaks down oil.)
2. Does the engine share oil with the transmission? (trans. gears shear oil quickly.)
3. Is it a high RPM engine? (consistently over 10,000 RPM)
4. Does the engine have high-pressure plain bearings or low-pressure roller bearing? (Roller bearings require little lubrication)
5. Does the engine have a history of lubrication issues? (Shovelheads, Ducati Bevel-drives, Honda VFs, Norton Commandos, old Triumph Twins?, etc)
6. Placement of the camshafts (BMW airheads have the cam in the bottom of the sump, submerged in oil vs OHCs far from the sump)
7. Dry-sump VS Wet sump? (Dry-sumps generally have greater oil capacity than wet-sumps because they have external oil tanks with no limiting volumes.)
8. Oil capacity of the engine? (Yamaha YZ & WR 450 engines hold just 1 qt of oil -- won't take long for that to break down)
I'm surprised no one added,
9. Wet or dry clutch? (Friction modified oils or moly additives may cause slippage of wet clutches.)
Lets review my 1990 Yamaha 200cc single.
1. Air Cooled - hard on oil
2. Shared engine and trans oil - hard on oil
3. Not high rpm - easy on oil
4. Roller crank - easier to lubricate
5. No history of problems - easy on oil
6. OHC - harder to lubricate
7. Wet sump - hard on oil
8. 1 liter total capacity - hard on oil
9. Wet clutch - specific friction requirement
Yamaha recommends API SF mineral 20W/40 above 40F and 10w30 below 60F, changed every 3000 miles.
All of these should work fine.
15W/40 HDEO, such as Rotella T, $3 q (ChinaMart)
5W/40 Rotella T synthetic, $6 q (ChinaMart)
10W/40 four stroke motorcycle oil, such as Castrol Actevo Xtra 4t semi syn, $5 l (on sale)
I just aquired the bike, old and possibly neglected. So, I am giving it an initial "flush" with 15W/40 HDEO, which will be followed by the Castrol.
Whoa, whoa - I had a 1990 Yamaha 250cc single-cylinder street bike and it had horrible cam problems. I can't remember the model number, but it had a weird kind of trunk behind the seat.
Edit: found it -- a Yamaha SR250. Bad cam problems from oiling problems
