Engine Damage caused from 0W20/5W20?
Interesting reference. My recollection from back then was that 10w40 and SAE 30 were the main grades. One could find SAE 40 and 20 but anything else was not too common. This may depend on the region too.
When multigrade oils became the standard that pretty much eliminated the summer/winter grade regimen. Even back then, habits were hard to change.
Yea I don't recall seeing 10w-30. 10w-30 was just too light! I don't recall Ford recommending 20 but I know GM did.
Yea I don't recall seeing 10w-30. 10w-30 was just too light! ...
Y'all got that history backwards. My 1962 Chevrolet manual recommends 10W-30 (including "for sustained high speed driving when the temperature is above 90°F"), but doesn't even mention 10W-40. I doubt it was common yet.
From a 1968 manual:
Courtesy of: http://www.modifiedcadillac.org/documents/1960s/1968/1968 Owner Manual/
Very Interesting. I am glad to see documentation :)
I worked in the business from early 70's through the early 80's at a Mobil and at Atlantic Richfield and really don't
recall carrying anything other than 10W30, 10W40, SAE30 But I also don't recall it being "killer" cold out in the Winter back then.
I'll have to look at meteorological history to confirm that weather perception - It may be youth just not being aware of the cold.
- Ken
- Ken
Are the 5W,10W,and 20W recommendations mono grades?
Even though I'm a thickie,I don't go hog wild on the viscosity. 5W30 was the original spec for the K24 in the TSX,which is the higher performance version of the K24 Accord,and I've always used either 5W30 or 10W30 in mine. I feel a W40 or W50 would be too thick for a 4 cyl engine. So technically I'm still "in spec" with the oil I chose.
- Ken
Being young , we could stand up to most anything. As you also suggested, the weather patterns may have been different then. We go through cold periods and warm periods. If I recall correctly there was a doozy of a blizzard back East in the latter 70’s.
I remember a bad Winter in '65 and a real bad Winter in '78 in the Midwest.
I was out in that in 1978 driving around in my friend 1968 MGB convertible with the top down in Andover, Ma.. Then later in the day it got bad and we finally got stuck and we had to walk home. We couldn't find the car the next day, as they were all covered due to heavy drifting. Had to go around with a broom handle and tap for roofs or trunk lids under the snow. The drifts againts the house were one- story high.
If you were on the highway with a long commute - you were toast!
A lot of discussion to this but i am a thin oil guy and my basic explanation about this is:
oil = thick enough to create and hold an hydrofilm. =engine will be fine for the cars life.
oil = not thick enough and rod bearings will touch metal to metal even lightly= engine is gone in a couple of miles.
I dont think that in a combustion motor there is something like the motor being destroyed but it happens slowly.
If something is really wrong it happens in a couple of miles.
Bmw ran 10w60 in their M model 6, v8 and v10s and i dont think there are any cars who suffer as much bearing failures as those do. (even discussions about being too thick and thus causing failures.)
From what I read,those engines were junk and BMW used a W60 to try to mask the defect (read that here on bitog actually).
i don't know if it is better to bump this thread or start another but i actually was interested if anyone has comfirmed uoa that was 'bad' when running a 0w20 or a xw20. i assume a normal driver would not get a bad uoa but i mean maybe someone who drives there vehicle hard and or tracks it on a xw20
Gosh! Isn't this myth been debunked after it (5W20, etc.) became a reality a decade ago?
back in late 90s, internet posters would be chicken-little crying over the use of thinner grade (e.g. 5W20) in engines will grind them to a pulp, or die prematurely (in a few years time? or a few thousands of miles?) Fast-forward to 2012 where 5W20 is a norm for most consumer grade gasoline engines operated in NA: how many of them die prematurely and ended up in the wrecking yard? Better yet: ever heard of an automobile manufacturer making massive recall RE: oil too thin, need thicker oil on TSB to save their reputation?
2 solid examples I can bring forth:
1) dad's 7th gen civic (that oddball 1.7L 4) has been on 5W20 factory spec since 2000 (bought it as 2001 model) and it has over 163KK in it, still pass local emissions testings, engine runs really well (smooth) and no oil burning whatsoever.
2) past several years Ford F150 gasser spec'ed for 5W20 and no one, even those who let dealerships maintain their vehicles and does towing on a regular basis ever lead to massive recall due to too "thin" of the oil.
Lastly: after a couple of thousands of miles in 5W30, it would typically shear down to 20weight anyways...so what's the difference in this case?
Q.
In regards to the shear thing, that may depend on the oil that's used.
Yes, why did you have to dig this old thing out of the trash?
And a $35 spectrographic analysis won’t tell you what you’re asking. I believe that’s been discussed several times. With you in particular.
But I guess if you’re desperate for another thick vs. thin debate then this is what you’ve got.
I agree with you, and there are members here who steer through different oils with differences of less than 5 ppm proving their points. It’s like looking up an elephant’s butt, How about this. Let’s find the very worst UOA with a 5w20 oil to prove it can’t stand up to the task. ;)
Can we just have one ultimate "thin vs thick" sticky for this type of discussion? In the past couple of years, this place has become absolutely mired in the same topic over and over and over again, just with slight variations in thread title.
