- Messages
- 2,760
- Location
- Kentucky
I spotted an argument in another forum over the merits of engine braking going down grades.
Most were supportive of it, but a few had the position that engine braking somehow hurts the transmission and they would rather torch their brakes than an expensive transmission. One post in support of that stated:
"IDK if I am following how holding the car in a given gear is going to wear out a trans?"
"It's not the gear selection.
You have a torque converter in the equation. Its a fluid coupling device.
The fluid is being heavily sheared between the pump (engine half) and turbine (trans half).
This continuous heavy shearing of oil will raise temps drastically, and can play havoc on plastic thrust washers within the gear box and other sensitive components......
A trans oil cooler would help if you perform this maneuver often.
Towing has the same effect on the oil. "
Is there any truth to the idea that engine braking or holding gears without a load on the transmission is bad for it?
