Engine Air Filter for 2014 CRV
NJ
I ordered a Fram Ultra Engine Air filter for my wife's CRV. When I went to pick it up, they switched it with a Extra Guard. I returned it. They reason for buying the Ultra is it's rated for 40K miles whereas the Honda's MM usually comes on around 30k. Most all the filters I see say 12k miles or 12 months.
What is the general consensus for a filter that will get me to the 30kish for the MM to go off? I'm looking at ACDelco Gold and Carquest Premium. I have used OE Honda recently but I can't order them from Amazon anymore for some reason. Any others to consider? I don't need it yet but will in the next ~1k miles when I do the next oil change.
I'm running AC Delco Gold from rock auto in my Subarus. good fit. would think similar would work in your crv. Came in a couple of dollars cheaper each when ordering around four at one time.
Are you running them the 30 month / 30K miles that Subaru recommends?
Yes, mostly. May have changed at 25K once or twice. daughter subbie goes more than 30K because she isn't as mindful as I am. We also have some fine filtering dust that sometimes I change early, but overall 30K is fine. We hit 30K before 30mo and save bucks compared to the suburu pricing in town.
Best fit with the oem AF. I want the best fit. .02
Understand your position. I found Motorcraft air filter in my f150 to fit better.
Rough example: subbie dealer wants $79 to change air filter. Daughter does it for under $20, and she isn;t mechanically inclined. Our subbies are 100% sub parts less the cabin and air filters.
I just buy an oem filter at the dealer then install, myself.
Hey the oem filter from a dealer with an eBay shop. You will get the quality part, not a counterfeit, and have the convenience of buying online.
Honda filters are usually slightly oiled. I’d want that as part of the equation. Not sure which others might be…. Dense first time fit?
I just ended up getting an ACDelco Gold. With shipping, under $20. Honda wanted $35.
I know you already got a filter this time, but next time, consider this KAX which is red and looks cool and is also oiled like the OEM Honda air filter.
Unfortunately, Femota doesn't make air filters for your 2014 CRV, but they are awesome for other cars. Femota's air filters are also oiled like Honda OEM.
You can often find an air filter and cabin filter bundle for $20 or less. Both filters for the price of one :)
I didn't know that the Honda filters were oiled. I put one in last time and didn't notice. I'll keep an eye on that. I should be good for another ~30k. I also have one more Amazon Basics cabin air filter left to install.
If you're following the MM you're already behind the curve.
So far, I have been using Honda OEM engine and cabin air filters on my 2016 CR-V with 20 K miles per use and intend to continue 20 K mile service interval.
Are any filters better at fit and filtering than Honda OEM?
OP, with Fram gone the way of the Dodo bird, good luck finding a Fram Ultra Air Filter.
Another filter worth considering is high flow. Under $20 and is also oiled. The oiled media has quite a bit more capacity than a standard filter. They advertise 2x dirt holding. They are also disposable. As always YMMV, but hard to beat for the price..
