When people talk about the cost of keeping the EV ready to go being expensive, the question that really needs to be asked is - compared to what?
You can do nothing with either type at -17F
The EV will ALWAYS at least run if not in turtle mode for a while. It will get you to work.
The Ice may not start. Happens ALL the time.
You can plug the EV in for between 86C and 5 dollars a night (california) and start full every morning and jump into a warm car ready to go. You can do this in a garage, or in the driveway.
Bonus in winter -heating an EV in the garage raises the garage temp a bit.
Diesel heaters vary from about 750 watts to 1500 -so on par or more than the Lyric// EV
It's not really an option with a diesel to not heat it some way at -17.
You can idle the ice in the driveway consuming some fuel and also reducing your range in cali its around 4-5 a gallon. My v6 uses about a half gallon an hour and to get it really warm from -17 and clear the windows it needs about 20 min to half an hour. so a bit less money. Im also fouling the oil at an accelerated rate doing that and shortening my OCI so other costs to consider. It gets notably less mileage in cold weather as well - between the warm up cost and the lower mileage cost Im using at least as much money wise as the EV - and having to visit a remote location to keep the car fed vs just come home and park stinks.
No one can sell me that going to the gas station at 17 below is convenient or fun.
You can heat the garage to keep the ice warm - if you use electricity it will cost more than the EV,
Or run a kerosene heater in the garage - I get about a gallon for 15 hours, and k1 is about 10 a gallon. Id usually start it around 9-10PM before going to bed and kill it around 530-6 AM so get about 2 nights out of a gallon - back to 5 bucks a night. If you can find it at a pump you can run red kerosene for about half of what K1 cost but then you get to smell it. I have a source about a half hour away and I have 4 5-ers for kero.
