When I walk in or out of my garage, I jump over the sensor beam so it doesn't turn on the light
I need to replace the seals around the entry doors, if I could just figure out which kind to get. The seals on there now don't match up with anything I've seen online.
Used to love the way clothes were so fresh feeling / smelling and sun baked when they came in off those old clothes lines that were in every yard.This is something overlooked and I have always hanged my clothes to prolong them, not to save money on utility bills.
Use drying racks or clothes line(s) inside if room allows for it.
The benefit is clothes lasting much longer and not shrinking. Dryer lint is your clothes, towels and linens getting thinner and worn out.
Drying your clothes is hard on them.
Fewer/short hot showers. 100% leds
Not a bad with keeping the incandescent for heat in the winter . Instead of replacing all the incandescent bulbs with LED's ......I just replaced the ones I use the most .
Since I moved in and began tracking costs, rates have risen over around five years from $0.18 to last months $0.23. Rates are going up this month. I believe they plan to raise rates by 30%, but I think I also read 50% somewhere! They did at least state plainly that the increase affects only the cost of supply, not delivery.Same for us… it’s about $0.12/kWh, but then a bunch of riders tacked on… transmission/storage/improvement, fuel cost, power purchases from cogeneration and small power plants, etc. I effectively paid $0.18/kWh last month, but they don’t tell you all that you have to go digging through the website. The bill simply shows how much you used, how much all that costs, and tax.
When I pour the boiling water out from my cooking, I pour it into a dishpan. If I drop an ice cube on the floor, I chuck it outside into the wintry night.
When I walk in or out of my garage, I jump over the sensor beam so it doesn't turn on the light.
I remove the owners manuals and other weight from my cars to save gas.
But seriously, I'm running a "Mr Cool" DIY heat pump for its first winter, and loving it, although this really hasn't been much of a winter. Also have a wood stove and fuel oil boiler. I put a laundry rack in front of the heat pump, thing is like a hair dryer and it gets the clothes dry in under twelve hours. Keeps the household humidity in a better spot too.
Ride a van pool more than 2/3 of my commute distance, also gets me nap time. My Prius goes 2 weeks on a tank of gas even though my job is 60 miles away. My electricity is around 22c per kWH so I'm actually NOT plugging the Prius Prime in until gas exceeds ~$3.75/gal.
Hear you all on the teenagers, mine also consume lots of shower water.
This is something I always plan to do, but haven’t yet. My dad did this when I was a kid. The entire basemen’t was filled with clothes hung up with only some fans to dry them. I don’t recall the basement ever being too damp or smelly.This is something overlooked and I have always hanged my clothes to prolong them, not to save money on utility bills.
Can you shop electricity rates from various providers in your part of the U.S.?
My dear, long gone Cajun/Acadian grandmother had these thin metal / wire type of frames that were made to insert into pants legs for hangingThis is something I always plan to do, but haven’t yet. My dad did this when I was a kid. The entire basemen’t was filled with clothes hung up with only some fans to dry them. I don’t recall the basement ever being too damp or smelly.
I do recall that the clothes all felt awful and stiff for when we first put them on, but they loosened up quickly.
Good! Just continue to shop the prices every time your plan expires.Good point! Sorry, I forgot to mention that we did just that as soon as I got the notice. We’ll be locked in to a better rate, but the paperwork said it would take months to switch. Delivery charge will not change.
I rinse my body quickly, turn the shower off, scrub my body, then turn the hot water on to rinse off the soap. The rest of my family like their Hollywood showers.
The only time I shower is when I travel. I have a walk in shower in the master bath but I prefer bathing. I have a Kohler soaking bath tub with bask heating which is total bliss.
I have a large jacuzzi tub, but the previous owners must have left it sitting for a while before we moved in. I’ve used dedicated cleaning solutions and other things I found on the internet and each time the water ends up with a brown film on it. None of us really want to use it often, so it just sits there. Personally, nothing is more soothing after coming in from the cold than slowly turning the heat up in the shower and just standing there for 10 minutes. It doesn’t happen often, but man does that feel good.
I actually have a small kiddie pool in the jacuzzi that we use to bathe the little one. She loves it!
When we remodel that thing is getting ripped out! What’s even worse is that the previous owners have a pretty basic little shower. It’s got plenty of room, but it seems low budget for someone who has a jacuzzi. I assume they skimped on the shower because of the jacuzzi, but who knows.
Also check out door corner seals. Not the best video but you get the idea.
https://www.homedepot.com/p/M-D-Bui...s-for-Interior-Exterior-Doors-51501/203175626
