Originally Posted by ram_man
I bled all the heaters as well as the system tonight a couple of them definitely had a lot of air in them the system itself also had some air . However and I don't know how big a deal this is but I'm hopeful it'll make a difference. I found out that the previous tenant. Was a rental house had left the water pipe valve going to the wood stove on. This house has the electric boiler and has a back up wood stove to heat the water as well. So the wood stove was getting the hot water circulated through it and it was enough to make the stove very hot to the touch. The stove is out in the garage with the boiler so in essence it was heating a very uninsulated and very cold part of the house. Granted the thermostat is in the house and says when to kick on and off, I would still imagine taking water away from heating the inside to run it through something that isn't needed and can be bypassed would be somewhat of a waste.
