I bought a Ford Expedition about 7 months ago and it had 137,750 miles on it with an unknown maintenance history. The first time I checked the oil it was not showing at all on the dipstick and it took 2 1/2 qts to fill. A few weeks later it wasn't showing on the dipstick again...I was thinking what the [censored], the truck runs perfect and never smokes, and has no leaks.
I replaced the PCV valve with a factory Motorcraft valve. I also installed an oil separator in line with the PCV valve. I very quickly realized that all my oil consumption was through the PCV valve apparently from blow by in the crankcase. The oil separator would fill up every few days. I still continued adding new oil instead of dumping the separated oil back in. I went through an oil change with Mobil clean 5000 and it still consumed the same amount of oil.
So now to my "Solved" status: I changed my oil again and added Zmax in hopes of slowing down the consumption. I know what it does on aircraft engines since that's what I do for a living, but I didn't know what to expect on my truck. I used Valvoline Max Life 5w20 as it was suggested to me by the majority here on BITOG.
I still had to keep adding oil for the next month, every week I'd check it and add at least 1/2 quart. Then during the second month the oil was reading slightly low and I'd top it with just a small amount of oil. And now it's been probably 6 weeks and its actually over filled a little bit. Apparently I put too much oil in last time I checked it.
Now the oil separator still continues to catch oil, but it's not enough for the level to show any change. It's just an ounce at the most every few weeks. My other vehicles with oil separators catch the same amount of oil.
I'm considering this oil issue solved, and the truck now has 143,000 miles on it. I can drive on road trips now and not worry about bringing a ton of spare oil with me. I'm sure the spark plugs and catalytic converters are happy too.
