Wifes tahoe threw a CEL. Code showed a bad canister purge valve. Replaced that. Light came back on a few days later. Bad knock sensor now. Had to remove the intake manifold to replace them and their harness since GM thought putting them in holes that fill with water and destroys them and the harness was a good idea.
2 weeks later CEL is back. New gm knock sensor failed. Tore the intake off and replaced it.
Driving around waiting for the readyness monitors to set it throws another CEL.
Running lean. Low fuel pressure so It got a new Delphi fuel pump assembly.
Now the fuel pressure is good but it threw another CEL for a bad fuel tank pressure sensor thats part of the new fuel pump assembly.
Its been 2 months chasing the CEL trying to get it ready for a smog check.
Only have 3 more weeks till the tags are up. Might not make it at this rate!
