So there are a couple things I will share:
1. First check transmission fluid level, top off with quarts of Maxlife ATF if low.
2. Trans-X is the only thing I would ever use to try to help an ailing transmission make it farther. My brother has recommended this frequently for people who don't have a lot of coin to drop and nearly flawless results. It's the real deal.
3. Avoid Lucas anything like $5 hookers with undercover cops on stakeout across the street.
4. Lubegard Red to me is more for transmissions that don't have physical problems (i.e. worn out, as 4T60s tend to get), it is for sticky valvebodies, flaring shifts, etc.
I'd recommend follow these steps in order.
