- Joined
- Jul 28, 2024
- Messages
- 1,475
On the receptacle I sent, you would install the white and black on both hot lugs being the white is a hot conductor in your situation just identify the white with black or red electricians tape. The bare copper goes on the center pin shaped like L this is considered the neutral back when your wiring was current code. Its what is considered your “Grounded” conductor.Yes, the wire coming from the breaker to the receptacle is 10/2 Romex, with black, white, and bare ground. On the receptacle, ground and neutral are bonded via a bare copper jumper wire. (Wiring was not done by me)
