Electricians chime in please - 240V wiring mistake?
If your dryer has electronic circuit boards and digital displays it may very well need a neutral connection for the 120 volt power supply .
Good to know. My current one has no electronic displays or buttons. Just knobs. It's a basic GE, probably 7-8 years old.
To be clear, on the current outlet, there is a jumper wire between the ground and neutral terminals. Are you saying this jumper wire should not be there, or am I misunderstanding? Thanks
The way it is now, there is a slight change that the dryer case could become energized.
You could take the top off the dryer and see if the white wire is connected to anything.
That would be a cheap and easy first step.
It would be better to have a separate grounding wire.
The washing machine receptacle should have a ground or the nearest light fixture.
It just depends on how much you want to spend and how good you want it to look.
I was editing when you responded.
Pull the top off the dryer and see if the white wire is used.
That will tell you what you what you need to know.
I believe that's my point .
It’s confusing that the old wiring method doesn’t call the center pin ground it’s the neutral. essentially down stream and at the panel neutrals and grounds are bonded together with the exception of a sub panel.
Nothing wrong with 10-2 wire. As mentioned the dryer is all 220. It does not need a neutral. They used the wrong outlet. Most dryers end up with a cord set with a moulded plug.
Until convenience receptacles near ac disconnects techs would either run extension cords or have a cheater cord to rob 110/220 for their equipment from the disconnect box connecting to one hot and the ground.
Just because you can do it doesn't mean you should do it.
Introducing voltage/current on the grounding wire is not a good idea.
HVAC techs do that as a very temporary solution.... not a full time thing.
The jumper wire shouldn’t be there, it really should have a separate neutral going bad to the panel, the same gauge as the 2 hot wires. Needs another wire pulled. The jumper may need to be there because the dryer might need 120V to run something-timer, fan, etc. BTW, new dryers seem to come with no cord these days, will need to reuse the old one or buy a new one.
Of course this isn’t a common practice and shouldn’t be done at all. But hey the ac techs got a job to be done.
Thanks again to everyone who chimed in and helped me understand my outlet wiring situation. I now know what would need to be done to bring the wiring up to code. I'm going to leave this thread, but if you guys want to continue the discussion, have at it.
