Electric die grinder
JHZR2
Staff member
New Jersey
Anyone have one? What are the pros/cons?
Thinking to get one as a dremel on steroids, to do some small spot surface rust removals... that is, spots where id like more control than an angle grinder but more power than a dremel.
I can suppoort air tools, but id actually prefer one of the electric ones. There are a few US made options.
Thanks!
I have a cheap Ryobi and it gets the job done. DeWalt wheels, though.
If I need something cut or ground, I get it out. I've never overheated it or slowed it down.
I have the slightly not as cheap dremel style from harbor freight, has worked well for its size. Also picked up a cheap-o electric angle grinder from menards last year. Plenty powerful, and seems robust for home user use.
I actually really like the fact that with e-tools you don't have to worry about running out of air, or compressor storage and maintenance.
I have air and electric die grinders. They're both useful tools. If I could have only one, it would be the electric tool.
From the sounds of what you want to do with it a micro type air grinder would be just the tool, low CFM air usage and powerful but also controllable in tight spaces, a real finesse tool.
Check out vessel air micro grinders.
I have a Makita that I bought for doing cylinder head porting- no real downsides except for its size.
Personally I would be interested in going electric if only for the reduced noise.
I guess some people think the scream of an air tool is cool, but it ain't much fun for the people that live near you.
But... is an electric die grinder a good option for spot wire brushing stuff?
I'm sure there would be a situation where it would be handy. Personally I have always used a 4" or 4.5" grinder with a wheel.
