Originally Posted By: THafeez
Hey everyone,
Last time I changed my oil, the mechanic recommended using 10W30 rather than 5W30. 5W30 is what the owners manual says to use. He said that because its an older car, the engines seals can wear out and a thicker oil can help to minimize leaks, burning etc...
He doesn't know what he's talking about there.
IF your car was leaking, and all it ever got was half mile commutes, then the 10W30 MIGHT be a little thicker when cold...if most of your operation is warm, then no difference.
Viscosity is a very poor remedy for oil leaks...i.e. doesn't really work that way.
So what benefits can using a 10W30 have for example in the summer for a car that calls for 5W30?
Can a higher weight oil help an older engine during start up since both oils reach the same viscosity at 212C?
Does 10W30 shear slower than 5W30?
Starting in Summer, no difference between them.
Yes, a 10W30 will have lower rates of VIIs, and be (possibly) more shear stable as a result, wuthin a given brand/range of oils....HTHS will be about the same, so no really thinner or thicker in bearings and cylinder walls...10W30 may hold up better there, but it's a margin call.
Stick with 5W30 in future.
Hey everyone,
