Educate Me | Regular Syn vs High Mileage
Hello! Just curious about something. I see many threads on high mileage syn and regular syn, but I don't really understand why one would pick high mileage. Could you educate me on the scenarios?
For instance: If I use Mobil 1 Extended Performance 0w20 on my car from mile number 1 new and perform regular changes and all other appropriate maintenance, then why would I switch from using it to Mobil 1 High Mileage after 70,000 miles? Thanks for the knowledge!
Usually if your cars engine seals are getting weak or breaking down you would use high mileage to help swell them back up. You would know they were getting bad if you seen a lot of smoke on start up. The high mileage is also supposed to have better detergents in it to fight sludge.
I would say you answered your own question.
There is no reason to switch from MOBIL to high mileage unless you have a need to do so like a leaking seal or seals. Just keep running the EP 0w20 until that day comes, if it ever does.
This idea of switching at 75k is mainly marketing.
I should also add, that since I started driving in the 70’s with multiple vehicles over the years, I have never used a High Mileage oil. If I had the situation where a engine started to consume oil my first response would be to go up one grade.
Today’s engines don’t have all the gaskets and such like the old days. Beads of sealant have replaced many of those and High Mileage oil will have no effect on sealant.
Agree but I have had High Mileage oils stop seeping oil seals, for good, on my old junks.
Curious about this as well, my understanding is they contain seal swellers and are on the thicker edge of grade when looking at cSt they also supposedly have an additive package that is beneficial for older engines which sounds more like marketing unless you’ve got engine oil leaks. For consumption and no leaks I’d bump up a grade on normal. Seen plenty 300k+ engines on here who have had a steady diet of normal synthetic their whole lives and look clean enough to eat off of.
I also wonder if that 70,000 miles is a holdover from the days of yore when a car was basically trash at 100,000 miles. 70k is barely broken in, you’re only 10k from the first trans service in many cases.
After "can I use 5W-20 instead of 0W-20?" and is "20W oil just for CAFE?", this is probably the third or fourth most discussed topic here. Maybe look around a bit and see if your question is answered. It's been talked about a lot. You've been on here over a year and a half I'm surprised you haven't seen those threads.
Ask ALL the Q?'s you want! That's what the members are here to do, help out other members. Don't let some here deter you.
Same here mate, I have never purchased High Mileage oil, and even though Australia has a strong car & oil culture, High Mileage oil is one of the few oils that you don’t much see around. Not a strong call for it here, from what I can tell.
You keep going with your regular oil if that is working for you, and if your engine gets a bit tired and starts consuming oil then you step it up a viscosity grade. Usually keeping to the same brand, eg Mobil 1 0W20 to Mobil 1 5W30
Very true PimTac but it may affect you wallet. Yes the last High Mileage I ran in the Corolla was Pennzoil High Mileage 5w-20. It was on sale at Walmart for $14 something a Jug but they had a rebate running so it came down to $4 and change. Seems I find High Mileage oils on sale at times the regular band isn't same with 10w30.
Yes, if you get a High Mileage oil on sale at a decent price and it’s the correct grade & specs, then fill ‘ya boots.
Also some of the Mobil 1 High Mileage oils are quite thick and carry the Euro A3 spec, I see these as closet performance oils for those who don’t need extra ZDDP but want to run a name brand synthetic.
I generally use High Mileage oils for vehicles over 10 years or 100k miles.
A little thicker, a little more robust add pack... why not.
Based on the UOA I have seen they are usually thicker (because some of them burn oil), with more seal conditioner (because some of them burn oil), with more detergent (because they likely have more carbon build up at the ring pack, and out of warranty so emission system poisoning lawsuit threat is less likely), and slightly less fuel efficient if the engine didn't blow by or burn oil (thicker, to compensate for ring pack carbon build up and oil leak through seals, takes more energy to pump thicker oil, etc).
If you don't care as much about fuel efficiency they are actually a good oil to use on newer car too.
