Originally Posted by Gokhan
Back to ZeeOSix's very interesting and useful study:
Turbo gasoline direct injection (TGDI) engine-wear test development (January 2018)
It's interesting that people always talk about bearings when they talk thin vs. thick oil but neither 0W-16 not 5w30 had no wear on bearings whatsoever in any driving condition. This is in contrast to BMW M3 bearings, which they quickly fail even with 10W-60.
BMW's problem in that case was most likely an oiling system and/or bearing design and/or clearances issue.
However, the questions of piston rings and the effect of viscosity on them remains. As piston rings operate on all lubrication regimes (boundary, mixed, and hydrodynamic), it's very complicated, especially for different driving conditions. Neither thin nor thick seems to provide full protection in all driving conditions.
There has been other study data posted in this forum in the past that also showed that a higher HTHS oil helped reduce cylinder and ring wear.
There were some caveats with the study, such as absence of an oil filter, broken chromium segment of a ring, and leaked intercooler fluid in the cylinder.
I already mentioned that if an oil filter was used it would have skewed the wear data because it would have removed actual wear particles which is what they were trying to measure. So it makes complete sense that they ran the testing without an oil filter. They were looking for total wear, not trying to keep the oil clean.
As far as the slight ring chromium layer shedding and the inter-cooler leak ... they don't think it hurt the collected wear data.
