Isn’t their house brand - not SEF but SuperTech the same? I see a JASO FD mark with VPxxxxx on it. I also see the same for Home Depot’s PowerCare brand.Walmart sells VP racing premix. red armor premix should be at home depot.
HP2 is a very good oil. I haven't seen any weakness in it. Runs good, clean, cool, and smells good. Saber is also good 50:1 and 64:1, 710 at 45:1, k2 50:1, all good and smell good.Red armor is a great FD rated OPE oil…but it’s an OPE oil. It can never compare to the 2 stroke Kart and racing oils like Honda HP2.
Try HP2 if you want the best of the best.
Amsoil fans will scream from the hilltops how great it is. I’m working through 2 gallons of husqvarna low smoke that I got on clearance. So far so good. With non ethanol and a good steel gas can I get a few years out of 5 gallons. We used to use 5 gallons every two days. Non ethanol used to be the norm but is now the exception. As far as mixing richer than 50:1…why? We never had a saw seize and beat the snot out of them. We had 025s that would last 2-3 seasons and were only retired because they simply fell apart. Not the saws fault when they were smashed or fell out of a bucket truck. Our bucking saws were 044s and 046s with nothing bigger than a 32” bar. Top handles were ms200s with no negotiation.No 100:1 at full power is going to be good, I don’t care what it’s made of or what it claims.
One weakness is that a pint cost a little less than a quart of any other synthetic 2T oil. Another weakness is that it's available mostly online.I haven't seen any weakness in it.
Keep in mind than some of those may loose suspension with the gas below 60-50*F.HP2 is a very good oil. I haven't seen any weakness in it. Runs good, clean, cool, and smells good. Saber is also good 50:1 and 64:1, 710 at 45:1, k2 50:1, all good and smell good.
And you know this how?Red armor is a great FD rated OPE oil…but it’s an OPE oil. It can never compare to the 2 stroke Kart and racing oils like Honda HP2.
I'm not either.Keep in mind than some of those may loose suspension with the gas below 60-50*F.
For sure I know that for Motul 710. A friend of mind runs his racing kart with it and told me that it doesn't stay in suspension below 60*F.
Motocross, go kart racing etc are sports primarily practiced during the summer, so some of the racing oil are not designed for lower temps.
No two cycle oil really cleans. And this is from alot of inspection before and after with a bore scope.I own about a dozen chainsaws, some worth more than my car, and I’m big fan of RedArmor. It cleans well and every time I tear a saw down, there is a nice oily film on all of the internal components. I run 40:1.
I used to run HP2 and it’s fine at 50:1 but any richer and it starts to burn dirty.
Amsoil Saber, Amsoil Dominator and RedArmor are my favorite 2 stroke oils.
I might have to disagree. I have only anecdotal evidence, but I have a lot of it. I buy, sell and rebuild a lot of chainsaws. Professional grade saws that get used by tree services and loggers, not homeowner saws that are used once or twice a year. Most of them come in rough shape with heavy deposits on the top of the piston, the exhaust port, and in the roof of the cylinder, and always the muffler. I pull the cylinder off of most of the saws I get, and at minimum I remove the muffler and spark plugs and inspect the piston, rings, and cylinder with a light. I’ve found that most of them, after 4-5 tanks of 40:1 RedArmor, are significantly cleaner than how they started. I’ve even heard some people recommend manually cleaning the piston and cylinder before switching to RA because it will remove so much carbon so quickly that there is potential for it to cause wear on the piston, almost like a gritty polishing compound.No two cycle oil really cleans. And this is from alot of inspection before and after with a bore scope.
You’ll often see black, oily liquid around the muffler port for the first tank or two. This goes away after a few tanks, presumably after the deposits have been softened and expelled from the cylinder.
RedArmor advertises that it cleans and removes deposits. I’m not sponsored or affiliated with Echo but it’s a great product that I’ve had an excellent experience with.
The only claim that RedArmor makes that I think is BS is that it is a fuel stabilizer. It might stabilize fuel to some degree, but I don’t trust it or any other fuel stabilizing product. I only use ethanol-free fuel in 2 cycle engines.
I've ran alot of Red Armor and I am going to have to disagree. If your seeing a wet muffler you have improper carb tuning, low load, or both.I might have to disagree. I have only anecdotal evidence, but I have a lot of it. I buy, sell and rebuild a lot of chainsaws. Professional grade saws that get used by tree services and loggers, not homeowner saws that are used once or twice a year. Most of them come in rough shape with heavy deposits on the top of the piston, the exhaust port, and in the roof of the cylinder, and always the muffler. I pull the cylinder off of most of the saws I get, and at minimum I remove the muffler and spark plugs and inspect the piston, rings, and cylinder with a light. I’ve found that most of them, after 4-5 tanks of 40:1 RedArmor, are significantly cleaner than how they started. I’ve even heard some people recommend manually cleaning the piston and cylinder before switching to RA because it will remove so much carbon so quickly that there is potential for it to cause wear on the piston, almost like a gritty polishing compound.
Not a thing.I have seen good 2t oil release deposits formed by inferior 2t oils back in the 80s, in a shop where we saw hundreds of engines every season. Sometimes in bigger flakes that would clog some muffler baffles partially. I’m not disputing your experience, just stating mine. I see the same thing today in my rotaries.
Ran some in a car four stroke also as experiment saw cleaner piston top after a few tanks at 1oz.
YMMV, but to me it’s a thing, and repeatable.
