I suspect the tachometer in my car (1992 Honda Accord) is not working properly. Kind of hard to explain, but it seems to be a little low at idle and maybe a little high on the highway, otherwise it works fine. It's a small enough difference where I can't tell if the tach is off, or if it's telling the truth and something is going on with my engine. So is there an easy way to verify the RPMS? I guess my only option is to buy an aftermarket tach and hook it up? Keep in mind this car is a 1992, so I can't just plug a scan tool into a diagnostic port to see RPMs.
