So driving home from work the other day I was pulling out of a road and it took off and felt like I was in 3rd. Put it in neutral and into 1st. Still bogged and then popped, banged, and misfired till it caught. Now the car will no longer rev past 3400-3500 rpm's. Occasionally it will let me go past it, but most times not. Almost feels like it's running out of fuel. Luckily for me even though the car is a 1995, it's OBDII. The check engine light has been a permanent stable of this car so I had it scanned. The only code stored is a P0171 bank 1 too lean. No misfire codes. Would this be an indication of a failing fuel pump or simply the fuel filter is plugged? The filter looks pretty crusty and likely hasn't been changed in a while.
The car is in time and idles fine. Sometimes it will bog on a cold start taking off and eventually catch. Also if I'm coming to a stop and clutch it, it will die. However it'll immediately start back up. This is the Chrysler non turbo 420A.
