Run E10 or E15 but switch over to E0 if you plan to store for longer than 30 days.
You can use E10 if you are burning through it. It doesn’t store well even with StaBil or Startron. I pay more and use real gas.I generally use 87 octane E0 treated with Stabil Storage in the garden tractor. However, E0 is currently expensive and the manual states E10 is acceptable. I also see that some folks here use E10.
How about using E10 through this season, then runing a tank of E0 at the end of the season before storage?
What types of problems would I invite by doing this?
I got a broken down commercial mower for free last year and after cleaning the carb and a bit of tinkering got it running. It last ran in about September of last year. Yesterday I go to fire it up and realize I hadn’t drained the fuel last time so it sat all winter with e10. It wouldn’t start so I pull the carb apart again and voila! Gooey sludge in the jets, bottom of the bowl, and impeding the movement of the float needle. It was spotless last season cause I put it in my ultrasonic cleaner so after 9ish months of sitting the ethanol had caused enough problems to stop it from running. The grunge wasn’t hard yet. It was roughly the consistency of creamed honey. I suspect if I had tried to start it after only 5 or 6 months of sitting it likely would have started and slowly worked that developing junk out of its system.
100 percent it was. Last year the machine got all new fuel lines, filter, pump, shut off valve, and the plastic tank was physically wiped clean (massive fill opening). The fuel system was as spotless as can be.And you think the ethanol caused that sludge? Or was that sludge in the gas tank and in the fuel lines and the ethanol dissolved it and moved it to the carburetor?
I had a car that was sitting for 10 years with E10 gas in it.
No sludge anywhere, but plenty of rust in the metal gas tank and the filter.
Added fresh gas to the tank after replacing the open-circuited fuel pump and it started right up. (Throttle-body injected).
Later on, replaced the tank and the fuel filter due to the rust.
I do this every spring. Customers give me their mowers when they hire me to do their lawn after their mower won’t start. It’s always a gummed up carb without fail. Clean out the goop and away it goes. If you shell out the extra bit for e0 gas it’s a non issue. It seems like people in some areas of the world have less ethanol problems than others. Must be something about the formulation or additives in the gas. Perhaps something to do with climate.
I see some recommend 1 oz of tcw3 per 5 gallons. Its nice to know that enriching the ratio to 1 oz per gallon works also.I started running TCW3 at 1 oz per gallon, in all of my OPE.
Yes sir, I run it at 1 oz per 5 gallons in my vehicles, and at 1 oz to 1 gallon in my OPE. The spark plugs always come out clean, looking normal, and no oily residue on the plugs or the exhaust, so I am a fan.I see some recommend 1 oz of tcw3 per 5 gallons. Its nice to know that enriching the ratio to 1 oz per gallon works also.
