Originally Posted By: salv
E10 does cause sludge. Ethanol attracts water, so anywhere that gasoline goes, water goes too. Water is also a combustion byproduct of ethanol. When water gets mixed with motor oil under heat and pressure, it forms a sludgy, emulsified goo.
Ethanol has no benefit in motor oil other than operating as a fuel line antifreeze.
Anyone that tells you that it is a step closer to alternative fuels is wrong. Ethanol as a fuel is very inefficient, dirty burning, and very expensive to produce.
It is time to abandon ethanol entirely.
The corn lobbyist have a lot of power so that will never happen.
I'm converting my supra for e85, the other supra owners I know absolutely love it since it has a higher octane and you build boost quicker due to additional mass ( you have to burn about 30% more e85 when compared to gasoline for stoiciometric burn.
To the OP. I've never seen sludge issues with E10. The causes of sludge have a lot of variables...how one determines the cause of sludge directly attributed to E10 will be difficult.
